SUNROOF STUCK!!! UGGGGHHHH
Old Jul 24, 2006 | 10:17 PM
BenzC280's Avatar
Default SUNROOF STUCK!!! UGGGGHHHH
As the title says the sunroof is stuck and my prior post about my a/c and heat not blowing anything at all out of the vents. Is this an electrical problem or are the motors just going bad...The sunroof was working perfectly until today when I put it back and now it wont shut. If it is an electrical problem should i get it fixed at mercedes? I think that would be best but let me know my options, thanks guys.
Old Jul 24, 2006 | 10:50 PM
rexde1's Avatar
Default RE: SUNROOF STUCK!!! UGGGGHHHH
There should be a tool to at least shut the sunroof, sort of an allen with two 90 deg. angles on it.
Old Jul 25, 2006 | 03:13 AM
BenzC280's Avatar
I have the tool now that you describe it, but I have no idea where to use it..? Any suggestions the manual doesnt say anything.
Old Jul 25, 2006 | 04:00 AM
rexde1's Avatar
You should fine a small round plug in the roof to the left side of the sunroof. Pop it out and stick the tool in and crank it shut manualy.
Old Jul 25, 2006 | 06:05 AM
rexde1's Avatar
If that wasn't quite right, It should be under the left dome light cover.
Old Jul 25, 2006 | 06:09 AM
sleepwalker's Avatar
yes. pull out the dome lamp lens.
Wedowee
Sep 12, 2012 01:21 AM
PaulGS
Dec 20, 2010 11:23 AM
Damcgreg
Apr 12, 2007 09:42 AM
CollectiveSoul
Feb 18, 2007 03:54 PM
Howie
Jul 30, 2004 09:00 PM
