Sunroof problem
Haven't had this problem before. My sunroof will open all but the last 6 inches. While when I set it to autoclose it closes all the way then continues to lift up in the back as if I just opened it that way. I cannot get it to close and stay closed is there some trick to getting this to close? Or even open all the way? I can't bring it to the dealer because I'm sure they will want to replace the whole unit to make more money. Somebody please help!!!
I have replaced the battery in the last 2 months but within that time I have taken it to the dealer twice both times having it hooked up to the computer. It was never brought to my attention. Also i drive with it open pretty much daily and it hadn't happened this problem jus started on Saturday. I do not have a manual so I cannot referto it for info. If u happen to have it could u shoot me an email with the info it would be much appreciated.
@joeval - can I adjust it myself or would this have to be done by a tech?
The lack of snychronization will not show up on the dealer computer since it is not an error.
There may be something else wrong but the instructions to re-synch are below. By chance, I just wrote these out a few days ago. The instructions are from my manual for my 2002 C230 sport coupe with panorama roof but from other cars I've owned I believe the instructions are the same. Sunshades instructions may not apply if you don't have them. What year is your car? Coupe or sedan?
To synchronize the panorama roof: The 2002 manual states the following:
Move the switch in the "close" direction, wait until the sunshades are fully closed. Hold on the switch for approx. 1 second.
Move the switch in the "open" drirection, wait until the sunshades are fully opened. Hold on the switch for approx. 1 second.
Move the switch in the "open" direction, wait until the panorama sliding roof is approx. 4 in (10cm) opened.
Move the switch in the "close" direction, wait until the panorama sliding roof is fully closed and hold the switch for approx 1 second.
As I recall, this procedure syncs both the sunshades and the roof. I personally have held the switch for longer than 1 second.
Good luck.
Good luck.
CollectiveSoul
Feb 18, 2007 03:54 PM
