1995 S420 sunroof problem
Old Jan 18, 2007 | 06:11 AM
BruceG's Avatar
Default 1995 S420 sunroof problem
Does anyone have any advice on how to trouble shoot why the sunroof fuse will blow whenever power is applied? I have tried to remove the motor assembly from the trunk, but have only dissembled it without getting it off of the spiral cable (or whatever its called).
Thanks in advance,
Bruce
Old Jan 20, 2007 | 04:28 PM
cool's Avatar
Default RE: 1995 S420 sunroof problem
check your motor (power sunroof) and make sure it is working otherwise if it is short circuited it will never stop to blow out the fuse. also you might want to check and make sure the fuse you replace is the same rating as the original one.
grg1966
Jun 1, 2012 12:25 PM
CollectiveSoul
Feb 18, 2007 03:54 PM
BruceG
Jan 23, 2007 07:10 PM
BruceG
Jan 23, 2007 07:02 PM
BruceG
Jan 23, 2007 02:53 AM
