starting engine problem?
Old May 11, 2006 | 07:17 PM
benzpimp's Avatar
Default starting engine problem?
When i strat my car in the morning or when its been a while it has a hard time starting up is goes from 5rpm to 10.5rpm. i hear it struggeling itself to start up. i was wondering what is wrong with it, and what can i do. any ideas would be appreciated.
Justin
Old May 12, 2006 | 02:14 AM
sleepwalker's Avatar
Default RE: starting engine problem?
dirty throttle valve.
clean it.
it will surge twice or thrice upon starting...then everything went fine....right?
Old May 12, 2006 | 06:20 PM
benzpimp's Avatar
Exactly How do i clean it with a breeze. please post links or pics
Justin
Old May 12, 2006 | 10:08 PM
pull up the intake mannifold plastic cover. it's just a clip, so nothing to worry about breakage.
loosen the hose clamp on the air intake pipe... on air mass sensor.
now you will see 4 allen screws holding the throttle valve.... remove the two screws which holds the intake pipe.
spray with good amount of carb cleaner and wipe with cloth. you may open the butterfly valve so you can clean the edge well.
you're done.
m1943
Aug 2, 2010 12:17 PM
mbenz80
Jun 24, 2010 01:51 PM
GOMES
Nov 3, 2009 05:54 PM
Hannu
Nov 14, 2007 11:52 AM
patrickx11
Jun 17, 2006 04:42 PM
