Radio Fan stays on= Dead Battery
Well I have been having this problem for quite sometime now... I own a 2001 C320 and am new to the forums... I tried searching under many different ways of wording this but cant seem to find anything. When I shut my vehicle off, the fan in the radio stay on until the battery is completly toast. Ive already ruled out the electronic seats cuz they are both unplugged and the battery is still dead when I let it sit over night. Is there a way to disconnect the fan or whatever is making that noise in the radio? I currently have my dash appart and am wonding if there is a wire that I can cut that will stop that current of power or sometype of relay? Thanks in advance and hope someone can help this problem
I had the same problem. It's probably your seat control module under each seat.
Take your car to a Mercedes mechanic who has proper diagnostic tools for the electrical system, I think it's called the CAN?
Anyways, if they disconnect each of the seat modules and then check the current draw, they should see it drop drastically.
I had one mechanic say I had to replace my entire COMMAND system and then I researched it here and had him test it with the seat module disconnected. THAT was the answer.
I then took it to a DIFFERENT mechanic and got the set module replaced for about $150 or so. No more problems.
Hope this works for you.
now my A/C compressor is malfunctioning.
Always,
Gramma_Benz
Always,
Gramma_Benz
Anyone solved this? I need this fixed really bad. Same exact thing, fan inside Nav/Radio keeps on spinning the whole time. took the whole thing apart but can not find the fault. for now im driving without the radio and pulled fuse #64. I have a 2004 CLK500. Please contact me or leave an answer on this blog since i am running out of options and driving to work half an hour in the morning without radio drives me crazy.
Thank You
Thank You
seems like the comand (radio/nav) will not go in sleep mode if there is a draw somewhere. Mine was the horn fuse 43 and after pulling it out the comand doesnt keep that fan on in the back of it. Now i have to fix the issue with the horn.
Hi Can someone please clarify - I have a problem with the COMAND module drawing power when ignition is switched off and fan continues running. My garage says the COMAND module is faulty and need replacing (too expensive!) but comments above suggest it might be something else i.e. the horn?
ginzbenz
Oct 17, 2009 07:40 PM
