Mercedes repair secrets
Old 05-03-2007, 02:27 PM
Default RE: Mercedes repair secrets
Hello star_expert,
I wasn't sure how to contact you so I made a post about my ignition lock in a topic here.
https://mercedesforum.com/m_75153/tm.htm
Let me know if you can provide any insight as to how I can get this resolved short of buying a new switch.
  #52
Old 05-03-2007, 09:14 PM
My 1997 C230 shifts very eratic, if left in drive and excelerated normally it will act as if it is in neutral when shifting into 5th gear and it does simular things when starting off in 4th.It drives down the road great it doesn't slip once it is going down the road.It also has what sounds like a vac leak under the dash on passenger side that only happens when the a/c is turned off.It is coming from a little box with about 8 colored vac lines going to it.What is this box? It also gives the code PO700. Can anyone help me figure out something? EMAIL: aa73034@aol.com
  #53
Old 05-04-2007, 12:36 PM
hi, i have a 2001 C240 (model 203, engine 112.912) pulled code P2007 intake manifold pressure low, i replaced the map sensor and the code comes back after about 20 minutes of driving. now i get the same code as well as P2085 self-adaptation of mixture formation for left bank of cylinders. cant figure out what to do next please email me @ mhickton@gmail.com with any help thanks in advance
mark
  #54
Old 05-08-2007, 01:27 AM
Star_Expert,
I have 2 questions...I havea 2002 C230 Coupe and wanted to change the brakes and rotors. Do you know where to find instructions for this...Also, I needed to replace a speaker in the door and wanted to know how to remove the door panel without damaging anything or setting off the airbag.... Thanks in advance..cbionic@aol.com
-Cb
  #55
Old 05-09-2007, 11:42 AM
Hi I am in need of a wiring diagram for a Merc c180 w202 dashboard lighting circuit , I have an intermittent fault that is quite annoying .Is anything available?
  #56
Old 05-10-2007, 12:24 PM
Hi Star_Expert,
Do you have instructions in changing the seat control module that is under my seat? Thanks. (2002 C320 sedan)
  #57
Old 05-15-2007, 02:43 PM
How do I change the fuel gauge control my gauge will drow to 0 then reture to wha tis real in the tank
Thank you Jim
  #58
Old 05-16-2007, 12:14 AM
muttley's Avatar
Hello Star Expert --
Newbie here.
How much [ft lbs / in lbs / Nm] of torque should I use to tighten a water pump on to the engine block of a '96 C220?
Appreciate it.
  #59
Old 05-20-2007, 02:35 PM
Archers's Avatar
Help please Star-Expert
I need to replace the door mirror indicator lamp assembly of my 2004 C Class Elegance. How do I remove the mirror cover?
richardgrice@btinternet.com
  #60
Old 05-21-2007, 04:14 AM
sleepwalker's Avatar
i cannot see any prompt replies to this thread.
you guys post your questions on a new thread and there's more possibility that it will be answered.
i am going to lock this thread temporarily to save your time and effort.
Quick Reply: Mercedes repair secrets
