Mercedes repair secrets
Old 03-25-2009, 10:53 AM
fuentucho's Avatar
Default water in passangers side.
Originally Posted by star_expert
All secrets of how to repair your Mercedes car as easy as 1 , 2 , 3 .
Problems in Keys
Problems in ECU
Problems in O2
Variant Coding
Airbag modifications
ATA ( Anti - Theft Alarm System )
All Star Diagnosis faultcodes repair+ Programming
All you need is just send me the problem that your car is facing , and i will send you the repair instructions.
My 1995 C280 have a water leak in passanger side. When I wash the car or when its raining water cames in and the floor looks like a swimming pool. The blower of the A/C is out of service due to the water. Where is the "hole", and how can I fix it??. Sorry by my English. Im in Argentina. Thanks.
  #102
Old 03-25-2009, 11:17 AM
vicrit36's Avatar
Default Wing mirror flasher
Hi, I have a 2001 C180 Avante Garde. The drivers side wing mirror flasher stopped working a while ago. I took it off and it looked like one of the LEDs had died so I bought a new unit from Merc and replaced the unit, but the flasher is still not working. Could you tell me what might be the reason for that? Also the one touch opening/closing on the drivers side door no longer works, one touch opening works on the rear passenger window on that side but not for closing. the front and rear passenger side is fine though. Thanks
  #103
Old 03-25-2009, 05:56 PM
32krazy!'s Avatar
im looking for instructions and tool list for lower a arm bushing replacememnt for a 2002 slk32. any help?
  #104
Old 03-26-2009, 04:13 PM
brudd's Avatar
Default star expert HELP with SBC
dO i NEED TO UNPLUG THIS SYSTEM TO REPAIR BRAKES ON A e320 OR IS THERE ANOTHER METHOD. . i'M DOING THE WORK FOR A FRIEND WHO'S DOWN TO THE LAST BUCK. i'VE DONE ALOT OF BRAKE JOBS BUT HAVE BEEN WARNED ABOUT THE E320 PISTONS SHOOTING OUT. CAN YOU HELP. tHEY GOT A PRICE OF 650 EACH END FROM mb.
  #105
Old 03-29-2009, 01:14 PM
go2dda's Avatar
I have C320 and what happened to mine was very similar with your descriptions, the problem was the accelerate pedal which have a sensor and it failure to adequately respond. When I change the accelerate pedal unit the problem is gone. I hope it will help.
  #106
Old 03-31-2009, 06:58 PM
stlhorse's Avatar
star man
can you tell me how to reset service B light
  #107
Old 04-02-2009, 01:45 AM
maniqz's Avatar
Default stalls when cold
hi, my 1994 c220 revs up high then low then stalls when cold...after at least 5 times of stalling then it idles normal, can you help me please...thanks.
  #108
Old 04-02-2009, 05:56 PM
fuentucho's Avatar
Smile your c220 revs up high and low.
[quote=maniqz;118729]hi, my 1994 c220 revs up high then low then stalls when cold...after at least 5 times of stalling then it idles normal, can you help me please...thanks.[/quote
Probably you have to watch the engine temperature sensor or the pressure of the gas pump.
  #109
Old 04-06-2009, 06:09 AM
vicrit36's Avatar
Hi, can you please tell me how to enable one click open/close on my C180 W203. Also have a problem with the drivers side wing mirror indicator, flasher unit stopped working so bought and installed new flasher unit but still does not work, any ideas?Thanks
  #110
Old 04-07-2009, 01:25 PM
Blue_AP2's Avatar
05 C230 K Brake & Rotor change. Thanks
Quick Reply: Mercedes repair secrets
