HELP! WHERE'S THE PUMP?
Old Jun 12, 2007 | 08:26 PM
brudd's Avatar
Default HELP! WHERE'S THE PUMP?
CAN ANYONE TELL ME WHERE THE FUEL PUMP IS ON THE 2000,C230 KOMP.AND IF IT'S IN THE TANK IS ACCESS THROUGH THE TRUNK OR DO I LOWER THE TANK? THANKS. I'M TURNING 100.000 AND CAR OCCASSIONALLY LACKS POWER UPHILL BUT IS FINE OTHERWISE. TUNED IT UP WITH NEW COILS AND PLUGS AND WIRES ABOUT 2000MILES AGO. NEW GAS FILTER.
Old Jun 14, 2007 | 09:05 AM
MasterBenzTech's Avatar
Default RE: HELP! WHERE'S THE PUMP?
it is located under the vehilce, in front of the rear tires. it is hiding behind a panel, that i think is held on with 3 10mm plastic nuts.
good luck
repl the fuel filter at the same time, it is right next to the pump(if you have nat had it replaced at 60k.
CLK320-Blue
May 22, 2009 03:22 PM
siliko
Apr 12, 2008 06:51 PM
YuCrew
Jan 3, 2007 09:25 AM
kanio
Sep 15, 2006 04:25 PM
w_white
Aug 30, 2006 09:02 AM
