dashboard glovebox door latch 2000 c230
Old Dec 9, 2008 | 11:23 PM
brudd's Avatar
Default dashboard glovebox door latch 2000 c230
How do i install a new latch on the glove box door. The metal loop on the inside is ok but the latch wont grab it>
Old Dec 10, 2008 | 08:57 AM
gregd's Avatar
Default RE: dashboard glovebox door latch 2000 c230
have you tried moving the loop out? if that doesn't work, take a thin screwdriver and use the shaft to check the latch. if the latch works, the loop needs to be adjusted either in or out. there are two screws, loosen them and there will be a little play forward and back. if the latch is broken, there are four screws on the inside of the door in the corners and two on the sides. remove these and gently pry off the back to expose the latch mechanism.
i hope this helps.
Old Dec 12, 2008 | 11:55 PM
brudd's Avatar
Thanks. I'll give it a try. joe d
Fastjackal
Apr 1, 2012 09:35 PM
broadbander100
Mar 9, 2007 05:13 PM
Kaiser Sozé
Feb 28, 2007 05:39 PM
broadbander100
Feb 18, 2007 12:10 PM
mryaya
Sep 6, 2006 12:58 AM
