2 Questions/Problems
Old Apr 16, 2006 | 08:19 PM
MBTeen's Avatar
Default 2 Questions/Problems
1) Can you replace the tail lights on an '03 C230 Sports Coupe? I searched for tail lights for a short time but didn't find any.
2) The feature where the windows go up/down if you hold the lock/unlock buttons on the remote for one second no longer works, though it did originally. What could be the cause?
Thanks!
Old Apr 16, 2006 | 08:41 PM
RockSolid's Avatar
Default RE: 2 Questions/Problems
1.) I'm sure you can change the tailights, but I don't the access point on your model.
2.) Two thoughts: If you've disconnected the battery recently, you may need to follow a procedure to let the automatic systems reboot. OR, perhaps the auto up/down will only work when facing the drivers door and you're no more than a couple of feet from it.( this is the case with my C280.) BTW, this is not true for other commands from the remote.
Good luck-that's all I know for now.
Old Apr 17, 2006 | 02:39 PM
MBTeen's Avatar
RE: tail lights I was wondering if anyone had, or if there are any available at all in the market. I know it's possible
I haven't disconnected the battery, and I have tried pushing the buttons on both sides of the car from very close.
Old Apr 17, 2006 | 02:57 PM
K1MOTORSPORT's Avatar
You can change your tail lights to 2005 style. For remote window close/open, try it several time and it will work. Sometimes it does not work at once.
Old Apr 17, 2006 | 05:02 PM
RockSolid's Avatar
Sorry, I misunderstood your question about the tail lights. Thought you were looking to replace a bulb.
Another note on the auto open/close function. If the car is unlocked and you've been unsuccessful at opening all the windows, you'll need to lock the car again before you try auto open. Same with the auto close except in the reverse.
Naki
Jun 25, 2009 02:13 PM
yellow427cobra
Feb 2, 2008 10:03 AM
youngmercedes
Jul 21, 2004 04:41 PM
cfkingfish
May 1, 2004 11:36 PM
