W124 coupe windscreen problem
Old Aug 11, 2008 | 11:05 AM
lola928's Avatar
Default W124 coupe windscreen problem
Hi, i am facing a problem with a permanent stain which is on the inside of the windscreen of a 1993, W124 CE. It is white, 2-3cm wide starting from the edges and i believe it is connected with the humid area the car came from. Any solutions how to remove this stain will be very helpful, thanks very much.
Old Aug 11, 2008 | 03:29 PM
gilgorm's Avatar
Default RE: W124 coupe windscreen problem
Based on your humidity comments it could be "scale" similar to what forms in coffee makers. Try the product "CLR" which is used to clean scale deposits. If the glass isn't etched a simple razor blade may scrape off the residue as well.
Old Aug 14, 2008 | 06:15 AM
lola928's Avatar
Hi, thanks for your reply, i will try what you suggest and hopefully that will be the remedy, all the best.
david_magee1
May 5, 2013 05:28 PM
romano6
Sep 5, 2008 02:12 PM
horseybird
Oct 27, 2007 02:12 PM
col190
Mar 5, 2007 11:36 PM
stinger
Nov 18, 2005 12:15 PM
