TEMPERATURE GUAGE READING HELP???
Old Apr 26, 2004 | 06:09 PM
notorious's Avatar
Default TEMPERATURE GUAGE READING HELP???
I have a problem with my 1995 C36 AMG It does not overheat but the temp does go a bit nuts in traffic its fine on the freeway/motorway.
The car also Pinks when temp gets over 100 oC then eventually the fans turn on somtimes just before it goes to red.
No water Leak or Oil mixes the ecar is still rapid and drives fine.
I NEED HELP PLEASE PLEASE PLEASE PLEASE PLEASE SO Le2Dynasty can you please give me a up date or can anyone else Help
PLEASE HELP I'M GOING NUTS I have had the car 4 years love it but I feel a very frustrated.
Old Apr 27, 2004 | 02:33 AM
Shan's Avatar
Default RE: TEMPERATURE GUAGE READING HELP???
check the temperature sensor switch that switches on the auxilliary fans through a relay.
The sensor is a on-off switch that switches on the relay to the fan at a specified coolant temp. The switch could be faulty.
You could get a replacement sensor switch with different temperature specifications e.g. 72° or 85°C.
I use one rated 72°C in my 1979 MB200 gas engine.
Le2dynasty
Nov 6, 2009 06:35 PM
toto
Sep 17, 2009 08:04 PM
borabora25
Mar 24, 2008 01:07 PM
WillCouncil
Oct 29, 2007 07:11 AM
rr_havuz
Mar 11, 2004 07:55 AM
