s430 Door asist problem
Old Sep 3, 2008 | 02:49 PM
s430on22s's Avatar
Default s430 Door asist problem
hi need asistance with my passenger side door asist. just resently started not working.I took the door apart and everything looks ok(conected) as i was thinkin because last time i had some work done on it the guys took the door apart and it stopd working took it back they said it needed a new asembli, but when they put it back together it workd. Ha got lucky i guess! This is not the same door that is acting up now. Do these units go out alot and how can i check to see if its bad. its a vacum system so kinda tricky
Old Sep 4, 2008 | 01:33 PM
s430on22s's Avatar
Default RE: s430 Door asist problem
ok guys I GOT IT WORKING was on the forum and ran into some one else with the same problem a member sugested to disconect and reconect the #62 fuse under the rear passenger seat and this would make the pump reset, well this this last nite and still the same problembut this morning every thing works maybee took a while to reset?
bdaved
Nov 12, 2011 01:32 AM
landsteam
Nov 5, 2011 09:26 AM
rlbmcd
Sep 21, 2009 07:20 PM
jnor
Jun 16, 2008 08:16 PM
gaby7588
May 28, 2008 04:40 PM
