QUESTIONS ON YOUR BENZ's I CAN TRY TO HELP!!
#71
RE: QUESTIONS ON YOUR BENZ's I CAN TRY TO HELP!!
Hey Buddy!
I got a 2004 CLK55.
When i take off i hear clicking sound coming from the rear of the car.Only on start after i hit a few mph it goes away.If i would stop put it in reverse and go slowly i would hear click,click,and the faster you go it stops.Any ideas?I'm shooting for cv joint or bushings???
Thanx!
Dean
LA
I got a 2004 CLK55.
Thanx!
Dean
LA
#72
I have an '82 300D. When I turn on the key the glow plug relay buzzes. I does not fuction the glow plugs. I purchased one on EBay and gor the same results. I changed the glow plugs same sound. Any suggestions where to go next?
Thanks,
BobS
Thanks,
BobS
#73
Hi Mar,
I think you are my last chance to get advise as i have tried everywhere even trying to understand the MB "WIZ" diagrams
I have a 1999 CLK 230K and both the front and rear fog lamps have stopped working.
Checked the bulbs. No power at the lamps. checked the boot cable. Checked the fuses and both are ok.
Tested that there was power to both sides of the fuses.
Any Ideas
Where do the wires go on the out side of the fuses. Is there another connector.
could it be the Switch and if i disconnect it will i need the onboard computer reset
I am confused
[/align]Any ideas please.
Len
Any Ideas
I am confused
Len
#74
I have a 1990 350 sdl, and it would go thunk when accelrating....I assumed it was the tranny, well I was driving on the Highway and around 110 km/h, I heard the engine revving high, looked at the rpms and they were hovering around 5000, way to high, I immediaetly got of the highway and drove normal speed on the city street, did not rev high, but would do the familiar thunk here and there. Well I started it again and I could here a wierd noise, on top of the regular diesel sound..what gives? Is my tranny dying, I'm pushing around 450k km. i'm freaking out here, please help...Thanks
#75
ORIGINAL: bobh307
I recently purchased a 1998 Mercedes 230SLK230 Kompressor(supercharged) and was wondering if it requires a timing belt change?
#76
ORIGINAL: Avid Edit
Greetings,
I have a 98 c280. and when trying to start, there is no crank, just a click.
Lights etc all work.
The car has been sitting for 3 weeks or thereabouts.
Any clues, or direction ??
Thanks!
Greetings,
Thanks!
#77
guys, masterbenz is no longer answering this thread.
please post a new thread to segregate the topic.
#78
ORIGINAL: Blondebrit
Would you know the crash rating in miles per hour on the 2005 CLK500 bumpers?
http://www.nhtsa.dot.gov/cars/proble...per/Index.html
That's to pass the Federal test. The lip won't pass a .00006 furlong-per-fortnight tangle with a parking lot curb. It's from The Government. They're here to help. It helps the insurance companies, who'll total the car out from under you if the bumper costs enough.
Bumpers have snot-all to do with "crash safety". True "crash safety" is only found in not crashing.
#79
Hi Masterbenz,
I was wondering if you could please tell me if a C180 2001 model was a safe buy?
I've been reading how unrealiable they are and they break down often.
What is your opinion?
BTW; I am in Australia but I am sure the Mercs in the US are the same [expect the left hand drive part].
Kindest Regards
AM
Kindest Regards
AM
#80
1990 300se
My 1990 300se was running fine . I replaced the thermostat. And took it on the freeway for a test run and as I was driving the rpms dropped really low, then went back up. I drove home turned it off and now it acts like it wants to start but won't stay lit! Help!
