QUESTIONS ON YOUR BENZ's I CAN TRY TO HELP!!
Old 03-09-2008 | 06:18 PM
ghenry's Avatar
Default RE: QUESTIONS ON YOUR BENZ's I CAN TRY TO HELP!!
Welcome,
I am having an intermittent problem with my driver window. It starts working for awhile then it stops. Also my CD Changer says NO CD Changer
Suggestions, please
  #12
Old 03-09-2008 | 06:23 PM
MASTERBENZ's Avatar
Banned
Year and Model???
-mar-
  #13
Old 03-09-2008 | 06:28 PM
ghenry's Avatar
99 C230, my apologies
  #14
MASTERBENZ's Avatar
Banned
I see it...1999 C230 Kompressor. I'm pretty sure what's happening with your car. It's shutting down your CAN (Control Area Network) System and it's using your driver's window as a default, which is common. My advice is to get checked at the dealership coz it's a little complicated than you think. There are several components tied into the CAN System, and you don't want to pay unnecessary repairs from an Independent Shop or Gas Stations. Dealerships use SDS, and they can diagnose CAN Problems on you car. I canfixyour car, but I'm here in VA., and I use the samediagnostic equipment as the dealership, and I charge a lot LESS!
take care,
-mar-
  #15
Old 03-09-2008 | 06:30 PM
zoober's Avatar
posted yesterday no reply maby you can help i have a2003 c 230 coupe with a check engine light on odb 2 scanner says code p0365 which is cam position sensor b bank 1 I am assuming that would be left side near the rear of the engine but cant seem to locate it to see if it will ohm out or not any help would be great
  #16
MASTERBENZ's Avatar
Banned
As far as your CD Changer...probably just programming in you D2B System needs to be configured via SDS.
take care,
-mar-
  #17
Old 03-09-2008 | 06:31 PM
ghenry's Avatar
Thanks,
Here's wishing I was in VA
I am not very happy with my only Mercedes dealership here.
  #18
Old 03-09-2008 | 06:35 PM
MASTERBENZ's Avatar
Banned
I apologize...
take care,
-mar-
  #19
Old 03-09-2008 | 06:39 PM
MASTERBENZ's Avatar
Banned
On your car, I believe you have two CAMsensors...one for the exhaust cam, and one for the intake CAM. My suggestion is that I wouldn't attempt to replace those CAM Sensors, because your car have CAM Advance Mechanism, and if it's not adjusted properly...you'll get a lot of drivability problems. You can check the resistance between the two wires, but whose to say it's not mechanical problem??? Becareful...
take care,
-mar-
  #20
Old 03-09-2008 | 06:44 PM
zoober's Avatar
Thanks Mar just dreading the trip back to the dealer the local shop is 2 hours away and nicknamed Jesse James moters lol Thanks again for your help
