E430 W210 Idler pulley removal
My drive belt snapped and I need to replace the idler pulley also (top pulley with ribs on it). I loosened the bolt that holds the pulley and it hits the fan when I pull it out. I have spun the fan and there is no gaps between the blades for the bolt to come out. To remove the fan, do I need to remove Radiator, shroud and viscous coupling? The viscous coupling has a large nut. Is this the short cut or does it all have to come out. Or does the I idler support have to be un bolted from the block?
Cheers Schnezza
Cheers Schnezza
bballfreak
Mar 13, 2015 08:04 AM
