320 idler pully replacement
Old Jul 27, 2010 | 07:29 AM
Charlie of Alabama's Avatar
Default 320 idler pully replacement
I have a 1999 ML230. I idler pully split and shereaded the belt. How do you pull off idler pully to replace it? 17 mm socket slipping off tensioner. Any suggestions there? Thanks
Old Jul 27, 2010 | 09:49 AM
Should be 320 ML not 230 ML
Old Jul 27, 2010 | 04:27 PM
chassis221's Avatar
should be a 17mm under the pulley or you have a T8 torx bit on the center of the pulley itself there is a holding hole to hold the tensioner while replacing it. 2 screws to take out the pulley easy fix.
bballfreak
Mar 13, 2015 08:04 AM
craig w
Dec 14, 2014 12:29 PM
2002c230benz
Feb 10, 2006 02:45 PM
piperca
Jan 22, 2006 01:47 PM
MLCLUELESS
Dec 28, 2005 10:13 PM
