ABS LIGHT
Old Aug 26, 2007 | 08:47 AM
edster224's Avatar
Default ABS LIGHT
1988 260E abs light intermittent, have good battery and alternator
Old Aug 26, 2007 | 02:19 PM
tric1's Avatar
Default RE: ABS LIGHT
check the overvoltage protection relay- behind the battery with the control modules- could have a blown fuse in it- also relay could be bad.
Old Aug 26, 2007 | 05:57 PM
NAZ's Avatar
NAZ
IF ITS A BLOWN FUSE LIGHT WILL STAY ON ALL THE WHILE,IF ITS INTERMITTENTLY YOU NEED TO CHECK THE SPEED SENSORS INDIVIDULY POSSIBLE GRIT OR STONE CHIP STUCK IN BETWEEN THE SENSOR AND THE PULSER RING....
sladedestiny
Aug 3, 2012 02:55 PM
Matz445
Oct 12, 2006 05:39 PM
Javelin220
Nov 14, 2003 01:44 AM
