97E320 check engine
Old Jan 8, 2006 | 11:46 PM
sandro6900's Avatar
Default 97E320 check engine
Hi guys!! First---A Happy and Healthy New Year to everyone!!Second---I Have a 97E320 with 75000 miles. The check engine light on the right cluster just came on, and as a double whammy, it also reads, under the speedometer, check engine electronics. Any ideas???? Also how can I get the check engine codes, and also what they mean?? Thanks in advance.
Old Jan 8, 2006 | 11:52 PM
sleepwalker's Avatar
Default RE: 97E320 check engine
sometimes the oxygen sensor value that is out tolerance which cause this check engine light to lit.
find a place where they got scanner to check the fault code.
Old Oct 7, 2006 | 07:15 PM
erhanerdonmez's Avatar
hi
i have the same issue. could you solve that problem/ it says check engine electronic.
nolen01
May 7, 2015 05:58 PM
solarant
Dec 27, 2007 11:34 AM
fluidmotion
Aug 19, 2007 04:19 PM
BlkE320Tinted
Jun 20, 2007 01:18 AM
BigFP
Dec 17, 2004 09:47 PM
