Smog question?
Old Jun 22, 2010 | 05:47 PM
82Benzo's Avatar
Default Smog question?
I have recently disconnected my EGR and the vacuum lines on top of the valve cover is that something they will look for when smogging? I can hook them back up if need be just wasn't sure if they'd care or not, or even look. It should pass smog without problems as is I believe, it runs well other than at low rpm's it's low on power, it doesn't smoke excessively throughout acceleration.
Old Jun 23, 2010 | 12:07 AM
Diesel9112's Avatar
Out here in CA they are only smog testing the newer Diesels; I do not remember the exact date.
However, on all of the smog checks here in CA the Person Doing the test is supposed to do a visual Inspection of the Emissions stuff to see if it is disconnected. That person puts into the computer if that stuff is OK or not.
On Gas cars they actually used to verify that your EGR was working by watching the Pintle move or by hooking up a Vacuum pump and applying vacuum at wich point when the EGR opened your Engine would stumble and your rpm would drop.
Now the Machine measures the Exhaust Dilution in order to determine if the EGR is working when it is supposed to.
They also know about putting a BB in the EGR Vacuum Hose to plug it.
In the visual inspection it is going to depend on how much the Inspector knows about your year,make, model and Engine.
Most States do not check Diesels at all.
Old Jun 23, 2010 | 12:09 AM
Diesel9112's Avatar
It would be a good idea to post what Car you have in you signature and also what state or country you are in.
Old Jun 23, 2010 | 01:16 PM
lwbrewer's Avatar
Same as Forced injection said for Pa all emmissions need to be in place and APPEAR opperable/ nothing disconnected. The inspection is a visuall
Old Jun 23, 2010 | 01:50 PM
82Benzo's Avatar
Default 82 300SD Nevada, Las Vegas
Thanks to all replied, yea gonna hook it up and take it to be smogged right now. I went to the state website and read the same mentioned above, visual inspection and such, so just in case it will be hooked up.
Old Jun 25, 2010 | 12:17 AM
Diesel9112's Avatar
I forgot to say that if the Inspector does not know your Vehicle he/she will look at your Emission/Vacuum Diagram sticker.
If the sticker is gone they may not pass you.
Old Jun 26, 2010 | 12:12 PM
82Benzo's Avatar
Thumbs up
Thanks for the heads up my sticker is in tact so I should be good.
marshman 442
Apr 3, 2008 03:56 PM
dvoraky
Nov 15, 2007 03:59 PM
garymand
Dec 16, 2006 10:35 PM
knave62
Aug 11, 2006 12:03 AM
Roman
Aug 31, 2004 05:28 AM
