Need to Pass SMOG, high idle and advance.
Old Dec 16, 2006 | 10:35 PM
garymand's Avatar
Default Need to Pass SMOG, high idle and advance.
My 90 560SELfailed due to 950 rpm idle and 30 degree advance, but passed the emissions with ease. Car runs great! I was directed to the EZL, but I can't prove it is causing thehigh idle. I don't have a spare, I'm trying to really find the fault due to the cost of an EZL, $$$. There's got to be some good techs who can help me sort through this and pin point what's wrong. I was directed to R16 and that made added a lot of fun to this.
I pulled the plug on the idle air valve and the idle shot way up.Idle does go down to 650 when I pull the vac off the EZL. It
Here's what I found with my EZL:
1)TDC sensor ~800 ohms engine cold (50degrees F, California), ~1050engine at temp. Expected, I think resistance in copper wire is heated. I expect a lot of windings in a magnetic pickup.
Below are all at idle in Park:
2) Removing vac drops timing to one of 5 steps set by R16 settings: 5ATDC, 0, 5 BTDC, 10 and 15. You can get three easily: R16 in (0, 5, or 10 BTDC), R16 shorted (5 ATDC), R16 pulled out (15 BTDC).
3) Applying vac at idle jumps the timing from one of the 5R16 stepsto ~25btdc then in 8to10 seconds later it jumps to ~30btdc.
4) From the R16step, EZL timingadvances smoothly as vac is increasedfrom <~10lbvac down to ~40lb vac.
5) EZL timingjumps in steps as R16 goes from 0 to ~3k ohms. (That is the full range of my EZL response to R16 resistance change.)
4) EZL respondsin 5 timing jumps of timing to 5RANGES of resistance:
0 - 145 ohms ~4atdc
150 - 330 ~0 tdc
350 - 675 ~4btdc
680 -3.0k ~10btdc
3.2k -0pen ~15btdc
5) R16 must be available in4 resistances about 100, 200, 512, 750, (and maybe 3.5k).
Mine measures 750, it is color coded 750and part# 000 540 24 81 I think Bosch 09 8659 24. That putsmy timing at 10.Shouild it?
Now I wonder if the smog tech should have pulled the vac line to expect 0TDC. And my R16 would need to be ~200 ohms do do that. And, Why hasn't this come up on earlier smogs?
Glassman300d
Feb 26, 2013 07:14 PM
donfs1
Jul 8, 2010 02:14 PM
rwaters711
Aug 25, 2008 02:34 AM
knave62
Aug 11, 2006 12:03 AM
Roman
Aug 31, 2004 05:28 AM
