Cold Starting Issues - 300D
Old Sep 15, 2006 | 02:29 PM
steamboatsykes's Avatar
Default Cold Starting Issues - 300D
I have a 92 300D that has just started to have starting problems when it is cold. The issue is also getting pregressively worse. Any thoughts? Thanks.
William
Old Sep 15, 2006 | 09:11 PM
81 300 CD's Avatar
Default RE: Cold Starting Issues - 300D
glow plugs could need to be replaced. how cold is it 50 degrees ? 0 or below?
Old Sep 16, 2006 | 10:27 AM
50 degrees at the lowest. It does seem fuel related, also noticing lower power, hesitation until the engine is warm. Thanks.
Old Nov 22, 2006 | 03:01 AM
otm646's Avatar
are you running diesel 2 yet? Diesel 2 is the winter varyant which is more voliatle and supposed to contain more anti gel additives. i would beck your fuel filters as when it gets cold the flow is even more restricted thus a loss in power. i always add some diesel 911 with antigel every fill up. it really helps in the winter because i run B 20 all year round
marbles300d
Nov 30, 2008 11:35 AM
Longhaily
Aug 2, 2008 07:28 PM
bluesky 2008
Apr 28, 2008 02:00 PM
DSM9.0
Feb 26, 2008 07:52 PM
Drskipper
Jul 22, 2007 07:14 PM
