A/C Cold air only lasted about 15 minutes after cold engine start ?
Old Jun 8, 2008 | 05:05 PM
Longhaily's Avatar
Default A/C Cold air only lasted about 15 minutes after cold engine start ?
06/08/08
Re: ML 320 year 2000. Air Compressor, Freon, Fan all working fine except the Cold Air only lasted for about 15 minutes after a cold engine start ?
Any suggestion / ideas are truly appreciated.
TechDummie
Email: Longhaily@Yahoo.com
Old Jun 10, 2008 | 10:32 PM
steamer1227's Avatar
Default RE: A/C Cold air only lasted about 15 minutes after cold engine start ?
uv got a leak somewhere in the system get some freon with uv dye in it and recharge with that find where leak is... fix.... 15 min u should be able to see where leak is cuz sounds like major leak somewhere good luck
Old Aug 2, 2008 | 07:28 PM
hdbill1@comcast.net's Avatar
you didn't say - after you turn the car off and let it cool down will the ac blow cold again or does it have to be recharged?
bruester
Aug 15, 2009 09:08 PM
merricke
Apr 21, 2008 12:09 PM
DeeNyC76
Jan 29, 2008 11:46 AM
DeeNyC76
Jan 28, 2008 02:16 PM
nagy1106
Apr 21, 2006 03:17 PM
