83 300SD 192,000 miles
Old Dec 23, 2009 | 06:03 PM
briansok's Avatar
Default 83 300SD 192,000 miles
Hello,.
I'm having (No) heat issues. The car gets up to tempurature, all of the coolant hoses are extremely hot, including the hose that passes through the firewall. When I push the heat buttons, nothing happens. No fan, no heat. Occasionally the fan will kick on and when it does all I get is luke warm air coming from the vents. Is the heating core clogged? Something else? Thanks for any help.
Old Dec 25, 2009 | 06:19 PM
Diesel9112's Avatar
I only know enough to know it could be an Electrical and/or Vacuum issue.
Old Dec 26, 2009 | 10:48 PM
cycleboy's Avatar
Does your AC work? Heat and AC are tied together. You can push the 2nd and 4th buttons in at the same time to remove the AC compressor from the circuit and see if it works then. Otherwise it could be a temp sensor or a vacuum issue.
Old Jan 24, 2010 | 09:00 AM
Unknownfl09's Avatar
There is a valve on the firewall that needs to be replaces. Sounds like it is stuck closed; therefore, not allowing heated coolant into the heater core.
jero2323
Sep 14, 2010 10:57 PM
Drew T.
Mar 7, 2009 08:56 AM
chaurap
Mercedes A Class
Jul 12, 2007 05:14 PM
youngandy
Feb 16, 2006 01:27 AM
sdnut
Aug 8, 2005 10:59 PM
