82 240D - Brake Lights out
Old Aug 27, 2007 | 10:27 PM
powsowb's Avatar
Default 82 240D - Brake Lights out
Brake lights seem to be intermittant on my 240D. Most of the time out though. (Both at the same time). All the rest of the lights work (parking, turn signal, reverse). Any suggestions for troubleshooting this problem. I have checked the fuses up front (all good). Have pulled the panels in back and the connections look good at the bulb end.
Old Aug 29, 2007 | 11:03 AM
Drrty240D's Avatar
Default RE: 82 240D - Brake Lights out
Mine did the same.I found thatcleaning the socket contacts with emery paper and applying a bit of silicone grease on the bulb ends fixed the problem. Clean any leftover emery paper grit from the bulb sockets before applying the grease.
Old Sep 6, 2007 | 11:21 AM
powsowb's Avatar
Thanks, that seemed to do the trick. Still has a hitch every twenty or so hits on the brakes, but it was not working at all.
Thanks again.
e55 ///amg
Feb 20, 2010 02:45 AM
mab
Nov 6, 2008 01:01 PM
slick1
Jul 30, 2007 07:05 PM
stevey88
Mar 18, 2007 05:19 PM
