240D Automatic transmission problems
Hello
I have a 1983 240D automatic with 350K miles It has been driving fine until i let it sit for about a week. Now it will not upshift. It wants to stay in first gear, If i play with the shifter from drive to neutral it will sometimes give me a hard shift to second but nothing after that. I checked the shifter bushings and they are ok. The vacuum pump is working .
Any suggestions?
Any suggestions?
Last night I was checking for vacuum leaks, Disconnected the vacuum modulator (VM) and found a split hose, Replace the hose then tested the VM, itwould not hold any vacuum. Started the engine and checked for vacuum at the engine side of the VM fitting. I had 26" of vacuum at idle. I hooked up the VM and tested the car. Everything shifted fine back to normal.
Soshould the VM be able to hold vacuum ?
