1992 300D 2.5, Need Advice Please
In USA we call it 300D even though it has 2.5 5-cylinder in Europe it is 250D. We never got 250D badges in USA but they gave us 2.5 engines with 300D badges.
thank you for reply.
Information code(wdbe......)
VINWDBEB28D9NB772400Model250 D TURBODIESELChassis1241281B772400Engine602962 12 014229Transmission722418 03 204497Order0 1 704 48899Approx. yearnot definedLightsBOSCHWiperSWFCab04404DealerUnited States (USA) (704) Interiormb-tex grey (178) Paint040black (T) (ñ 01.01.1963)78Unknown codeOptions221left front seat, electrically adjustable (ñ 01.11.1978)
central locking system (ñ 01.04.1963 ïî 30.09.1970)
222right front seat, electrically adjustable (ñ 01.11.1978)
first aid kit (ñ 01.11.1962 ïî 30.09.1970)
240outside temperature indicator (ñ 01.03.1982)
second spare wheel (ñ 01.01.1964 ïî 28.02.1973)
280trunk set, 3-piece (ñ 01.09.1964 ïî 31.08.1972)
steering wheel (400 mm dia.) and gearshift lever in leather trim; on W202 390 mm dia. (ñ 01.05.1984)
340additional 3rd stop lamp (ñ 01.10.1989)
front seat, right, lower (ñ 01.03.1967 ïî 28.02.1986)
412electric sliding roof with tilting device (ñ 01.07.1983)
hydraulic sliding roof, in the rear (ñ 01.11.1964 ïî 30.06.1981)
420automatic transmission, floor shift (ñ 01.01.1963)
430headrests in the rear (ñ 01.01.1977)
safety belts, front and rear (ñ 01.01.1964 ïî 31.05.1973)
444bumper, rear, with license plate higher than 152 mm (ñ 01.02.1967 ïî 31.08.1971)
tempomat (cruise control) and airbag (ñ 01.02.1980 ïî 31.10.1993)
467central locking system and instruments with english lettering (ñ 01.04.1970 ïî 31.10.1993)
461 + 462 + 463 (ñ 01.07.1968 ïî 31.08.1969)
491USA version (ñ 01.01.1963)
524Reims adapter IV (ñ 01.04.1962 ïî 28.02.1963)
paintcoat preservation (ñ 01.01.1964)
543exhaust-pipe cover trim (ñ 01.01.1963 ïî 28.02.1963)
seat adapter between the front seats, and halogen lamp unit (ñ 01.01.1967 ïî 31.12.1972)
sun visor with vanity mirror, illuminated, left and right (ñ 01.11.1978)
570folding armrest front w202/210 stowage box front with armrest (ñ 01.04.1970)
front folding armrest w202 - housing at front with armrest
588Thermoking air conditioner and electric window lifters (front doors) (ñ 01.04.1970 ïî 31.12.1972)
automatic climate control and electric window lifters (front and rear doors) (ñ 01.01.1977)
593headlamp flasher and turn signal lamps - italy (ñ 01.01.1963 ïî 31.07.1965)
headlamp flasher and turn signal lamps, front, crystal clear (ñ 01.08.1965 ïî 31.01.1967)
heat-insulating glass, rear window pane (ñ 01.02.1967 ïî 31.01.1971)
heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter
green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (ñ 01.01.1972)
611courtesy lamps for front and rear doors, with W124 also for central doors/W202 front doors only (ñ 01.11.1978)
sealed beam lamp unit, l.h. traffic (ñ 01.01.1966 ïî 28.02.1972)
lamp unit, symmetrical (ñ 01.01.1962 ïî 28.02.1963)
639radial-ply tires, elimination of warning triangle (ñ 01.11.1973 ïî 31.10.1974)
elimination of first-aid box and warning triangle (ñ 01.08.1977)
640aluminium disc wheels with radial-ply tires (ñ 01.10.1969 ïî 31.12.1989)
tires with tube (ñ 01.01.1963 ïî 31.08.1965)
15-hole light alloy rims (ñ 01.01.1990)
664tires 275/55 r 17 with chromed light alloy rims (ñ 01.01.1995)
wood rims (ñ 01.01.1963 ïî 30.06.1964)
10 liters of fuel and mode of packing VE III (ñ 01.01.1979 ïî 30.06.1993)
673high-capacity battery (ñ 01.01.1964)
757Becker radio Grand Prix 2000 - USA (ñ 01.06.1990 ïî 31.03.1994)
radio with cassette (loudspeakers and antenna included) (ñ 22.05.1996 ïî 11.11.1996)
802Change of year of model, last figure shows new model year
814active bass loudspeaker system (ñ 01.10.1989)
elimination of rear doors (ñ 01.11.1962 ïî 30.04.1974)
I fixed the small images.
I noticed the engine warmed up slowly, maybe I am just used to the rapid warm up on the aluminum head V6 I now have. Is a slow warm up normal?
The minimum things I would do to start out with:
Fix headliner ($200)
Fix driver door window regulator ($200??)
Replace headlight lenses ($200?)
Replace right front door glass ($200)
Antenna ($100)
So right off I can see $1000 of stuff to do with me providing the labor.
Antenna ($100)
Hi. i am from russia. excuse me, my english very bad. i use two models mercedes, w 124 250 diesel(engine602)1990 year and w 202 diesel(engine604) 1994 year . w124 have run 500000 km, w202 have run 300000 km. their engine work very well, run when outside it is -25
celsius. this mercedes very good, must carefully examine engine and turbine. front and rear axle very simple, repair them simply and not very expensive. i do it so afte shopping car , rebuilding all axle . enought about 2 years.
www.mbparts.ru in russia this is site shows price original parts by mercedes.
do you check oil presure hot engine? good pressure 2-3 bar, temperature engine 80-90 celsius degrees. this is engine also has aluminum head , if very long warmed up ,reason may be malfunction in the thermostat. it is not very bad and quickly change. it is not very well fuel pump dirty from the oil. repair fuel pump very expensive.
The Injection pump is a bit grimy , looks to me that it is original, likely to require rebuilding at some point in the near future. Dents scratches and dings look a bit tacky and are hard to get rid of cheaply. I would price it in the $2500-3000 range. Also looks like the underhood area has been heavily Armoralled. Cheers Dan
