Little drivers side window is stuck when top down is activated
Old 04-14-2010, 09:30 PM
sealluke's Avatar
Default Little drivers side window is stuck when top down is activated
99 SLK Drivers little window that goes down when tops activated (STUCK)
Today went to put the top down and the drivers-side little window that operates when the top goes down got stuck. The other side works fine. I know it must be a loose bolt/screw thats thrown it off track since it a 99. Does anyone know if you acccess that part of the window from behind the drivers seat or from the trunk? Any stories of the same problem you might have might have had. I just wanted a head start of what I was up against. Thanks to all..
LJT
1999 SLK 230 RED
macca55
09-30-2007 05:30 AM
1maxxfan
05-31-2006 02:55 AM
triumph57
02-02-2006 05:23 PM
s_gilbride
01-29-2006 07:51 PM
Quick Reply: Little drivers side window is stuck when top down is activated
