Little drivers side window is stuck when top down is activated
99 SLK Drivers little window that goes down when tops activated (STUCK)
-------------------------------------------------------------------------------- Today went to put the top down and the drivers-side little window that operates when the top goes down got stuck. The other side works fine. I know it must be a loose bolt/screw thats thrown it off track since it a 99. Does anyone know if you acccess that part of the window from behind the drivers seat or from the trunk? Any stories of the same problem you might have might have had. I just wanted a head start of what I was up against. Thanks to all.. LJT 1999 SLK 230 RED |
