Other Post discussion on all other models not listed above here.
88 560SEL power steering
Old Jul 17, 2005 | 05:28 AM
lasvegasman's Avatar
Default 88 560SEL power steering
A small leak just started this past week and it is coming from the steering box. I know it will need replaced eventually but so far the steering has not exhibited any problems like a noise or hard steering. What kind of "regular" power steering fluid can I use in the meantime?
Old Jul 17, 2005 | 10:09 AM
sleepwalker's Avatar
Default RE: 88 560SEL power steering
if the car haven't involved in minor accident which cause any linkage to bent, then the power steering box can still be repaired.
just replace the two oil seals. that will fix it.
Old Jul 17, 2005 | 01:52 PM
Is that a do it yourself project? Just get the seals at an auto parts store, drain it, and replace them? I'm fairly good at working on automobiles. I would still like an answer to the "what kind of fluid" question. Thanks for the response, though.
Old Jul 17, 2005 | 03:33 PM
your model uses ATF.
you can do it yourself but you need to remove the steering box. if the leak is only coming out on the pitman arm side, then just replace that one.
remember: mark the position of the pitman arm before removing because it will greatly change the toe of wheel alignment.
Old Jul 20, 2005 | 09:09 PM
MB/TECHMAN's Avatar
i can get a kit and reseal it for you ...done 100s
AMGMercedes
Apr 2, 2007 10:49 PM
ticex
Sep 13, 2004 05:15 AM
KLHAMMETT
Feb 24, 2004 11:12 PM
pparnail
Dec 14, 2003 11:08 PM
pparnail
Dec 12, 2003 01:11 AM
