a surprise after re-filling wiper reservoir
Old Dec 21, 2020 | 12:18 AM
brookings's Avatar
Default a surprise after re-filling wiper reservoir
shortly after re-filling reservoir, the wiper nozzles plugged up. the gunk in the reservoir got kicked up when I re-filled reservoir and got into the whole spray system. use a wire clothes hanger with a bit of cloth pressed on wire by bending the end of the wire back over the cloth. use to clean the reservoir, what a mess. went from one end to the other of the system. a needle does no good in cleaning where the sludge is located in the nozzle. I had to use high air pressure to dislodge the garbage inside the nozzle. it took some time in working it loose. the reservoir is accessed behind the front right wheel well. may want to clean before it plugs everything up if needed
glen washington
Jan 23, 2014 07:32 PM
phil2471
Jan 15, 2013 07:56 AM
evillwock
Dec 6, 2005 12:50 PM
evillwock
Sep 23, 2005 06:13 AM
Norseman
Jan 4, 2005 08:26 AM
