slk230 latch actuator cylinder
Old Aug 24, 2008 | 07:57 PM
cmshort's Avatar
Default slk230 latch actuator cylinder
I assume that is what it is called, the cylinder in the center front of the top that trips the latches when lowering the roof. 1999 model. The cylinder on mine is leaking and I was wondering if these are repairable. It looks like it is held together with a snap ring, may just be an o ring seal. Also, do the hydraulic lines to this go all the way to the pump. From what I can tell they appear to go in the bottom of the pump, looks like it would be a bear to replace. I assume this part is expensive new, just a guess. Any help would be appreciated.
Old Aug 25, 2008 | 12:48 AM
snanceki's Avatar
Default RE: slk230 latch actuator cylinder
"I assume that is what it is called, the cylinder in the center front of the top that trips the latches when lowering the roof."
?. Maybe a picture would help.
Stuart.
Old Aug 25, 2008 | 10:07 PM
bazzle's Avatar
Normally you replace the whole cylinder. The hyd lines are perm att.
Look here http://www.benzworld.org/forums/sear...archid=3105467
Bazzle
Malanena
Feb 25, 2009 05:46 PM
jons
Nov 16, 2005 08:44 PM
kenm
Sep 30, 2005 07:47 PM
vpmonroe
Aug 16, 2005 03:32 AM
