slk roof wont go down
Old May 11, 2008 | 11:09 AM
cooper1977's Avatar
Default slk roof wont go down
its a 1999 when butten is pressed the windows go down the boot lifts up the motor keeps buzzing but does nothing, checked the 2 micro switches in boot they seem ok the locks are opening on the roof could it be micro switches at top next to windsceen but how can i check them if roof wont open any help is much appreacheated
Old May 12, 2008 | 12:22 AM
brookings's Avatar
Default RE: slk roof wont go down
there is a way of manually opening and closing your topif you haveyour owners manual. in mine, it startson page 113.
Old May 12, 2008 | 05:41 AM
bazzle's Avatar
Give the roof a thump where the switches are.
The front ones go faulty more than the others.
The silicon bellows jams them up or the contacts go open.
Bazzle
Old May 12, 2008 | 10:30 AM
snanceki's Avatar
Is the hydraulic fluid level correct?
If the pump is running then it is unlikely any of the limit switches. These cut the pump supply under various conditions.
Has the hood just gone wrong or has it been removed / refitted / adjusted etc. by somebody?
Stuart.
Old May 13, 2008 | 07:21 AM
djinnaroth's Avatar
well you should know this if your hydraulic fluid level got low or in other meaning isnt giving the hydraulic the ammount of fluid , it might jam up your Bumpand your cylinders
well if you want the small windows to get back up you
can do things
either you open ur boot let some one press the butten of the Conv and you press the thing to close it
this thing will restore the system
or you can do it the hard way
which is to fill the hydraulic bump and close it
i recommend you to check for leaks on the wires or the cylinders or the hydraulics
take this extra note
consider this slk's under 2001 models have hell problems
not cause of the mechical things no its more of a software wise
what i really recomend all the slk owners is to go the servies and to reprogram your cars
cause belive me all the problems you guys are facing is programs
when it gives over load power it might burn or break down many things
soo try to do this and belive you will see defrence in the
perfourmance
electronical wise
andlessproblems
Take Care
Old May 17, 2008 | 03:28 AM
bazzle's Avatar
ORIGINAL: djinnaroth
perfourmance
electronical wise
andlessproblems
Take Care
WTF ???????????
Bazzle
Old May 17, 2008 | 10:03 PM
djinnaroth's Avatar
Belive me when ive heared this I freaked out 2
i have my cousen works in mercedes car softwares
he said all the errors and problems u have in the slk in gernal since 1997 till 2001 have a software problem
i had hell of problems in my slk like electronical stuff
convertable problems
car system computer freaz in meaning my lights start to go crazy by it self transmition is getting crazy in shifting
just after reprogramming th car
the car just works perfectly
with no problems
its been running on the new program for 2 years now and belive me its perfect
i even boosted the car from being 197 to 348 bhp by the mercedes serves there is nothing added just purely stock
kevinhuynh87
Apr 2, 2012 08:02 PM
sfag
Oct 18, 2009 03:07 AM
mrmambo
Nov 25, 2007 11:55 AM
iant61
May 27, 2007 03:19 AM
josh740
Apr 10, 2006 06:59 PM
