SLK Misfire
Old Aug 24, 2005 | 06:01 PM
  #11
bazzle's Avatar
Default RE: SLK Misfire
You cannot hold a high rev in static mode. with no load. It will cut. It is supposed to do that.
It prevents an over rev by someone bleeping throttle.
This has been researched on other forums.
230's also seem to have a very slight stumble at idle, esp in neutral.
http://www.benzworld.org/forums/foru...iew.asp?fid=26
Bazzle
Old Aug 24, 2005 | 10:50 PM
  #12
sleepwalker's Avatar
how much is the mileage?
Old Aug 25, 2005 | 03:48 AM
  #13
adelme's Avatar
I never use A/C...
But as you said, is it really a missfire or just small variations during idle ?
I never had any missfire at other RPM than idle.
Maybe I will try to have an engine diagnostic to my mercedes dealer.
Old Aug 25, 2005 | 05:35 AM
  #14
dondas's Avatar
The SLK230 is prone to the spark plug conectors causing tracking marks down the porecelin on the spark plug. If you remove your spark plugs, always keep them in order on the bench and then examine them for small black lines along the length of the porcelin. If these lines are present, there is your miss, but you must also replace the connector to the spark plug. It is most common on the connector under the coil pack, and is available seperate to the coil pack.
As for the SLK320, I would assume that they have checked the air mass sensor, purge valve, compression and checked for faults in the memory which would relate to the miss. Electrical missfires are normaly picked up as a fault code. From there, it should be checked for water. Check the fuel filter first of course, but the fuel rail doesn't have a return like the earlier models, and if water does happen to get into the rail, it just floats around causing problems.
Hope this helps one of you guys at least.
Old Nov 17, 2005 | 03:55 AM
  #15
tancalvo's Avatar
I have a 99 slk and took the red cap off where the spark plugs should be put how do i take them out
i have had several cars and changed dozens of spark plugs but this looks like nasa stuff please help..
Old Dec 4, 2005 | 01:43 PM
  #16
mbz811's Avatar
tell the dealer to inspect the wiring harness
the harness get contaminated with oil from the cam adjuster on the front of the engine
oil could be at the engine control module cause running probs
if your ceck engine light is on with a code saying o2 sensor short to ground/positive thats probably your prob
there is an updated adjuster and engine wiring harness that must be replaced and maybe engine control unit
all the dealer has to do is unplug the module and see if there is oil at the module
if not unplug the o2 sensor before the cat converter and see if there is oil
there is a bulletin on netstar about this condition
Old Mar 11, 2010 | 12:09 PM
  #17
andy82's Avatar
Originally Posted by Finman
Another point. When I was checking out the car after their last effort, I slowly revved the engine up (when warm) to see if there was any other misfire of notice. When I got to 4300 RPM get big misfire. Mercedes says it is supposed to do that when the car is at rest to stop over revving. Anyone else with a 320 that can confirm that idea. It is not mentioned in my manual!
I was told that is normal when not under load. Mine does the same thing.
mlbenz
Jul 21, 2006 12:36 AM
lhb consulting
Jul 24, 2005 06:08 PM
vinzbenz
May 3, 2005 06:42 PM
rogerpop
Apr 10, 2004 03:42 PM
posmaxx
Apr 7, 2004 12:10 AM
