Loose antenna
Old Jan 17, 2012 | 11:12 PM
Timslk's Avatar
Default Loose antenna
My antenna is loose at the base, how do i access to tighten?
Old Jan 17, 2012 | 11:14 PM
Timslk's Avatar
It's a 2000 SLK 230
Old Jan 20, 2012 | 11:17 PM
livefreeordie's Avatar
Remove the antenna from the base, there is a screw to tighten it down.
Old Jan 21, 2012 | 03:35 PM
Timslk's Avatar
Default Antenna
It's actually the base itself on the rear fender, the wire attaches to a connector that runs through a plastic base. I can not see any way it actually attaches to the fender?
Old Jan 22, 2012 | 10:58 AM
I never removed mine, i know there is a nut under the wip that comes loose over time. On the underside of the base there is either a flange that fits snug to the underside of the fender or there is a second nut/washer that came loose as well. You can get to it by removing the plastic panels on the inside of the trunk/boot.
Old Jan 23, 2012 | 07:30 PM
Timslk's Avatar
Smile Thanks
Thanks!
Old Jan 26, 2012 | 01:49 AM
Anytime. Did you get it fixed?
Old Jan 26, 2012 | 07:38 PM
Timslk's Avatar
The hard plastic base is loose in the hole in the fender, looks like a rubber type of insert is missing that holds everything to the fender? Looking online for a parts catalog that may show detail but have not found it yet. Also reception is really bad, may not be grounded. This is the only thing wrong on this car I just bought from a PP original owner with 100,000 miles otherwise like new.
Old Jan 27, 2012 | 08:14 PM
  #9
96SL500's Avatar
From: Manatee County, Florida- Sarasota mailing address
You may have already solved you rantenna problem, but here is a great site I saved when I had an antenna problem. Choose your car and it has numerous pictures that walk you through it.
www.AntennaMastsRus.com
Good luck
Old Mar 3, 2012 | 04:21 PM
  #10
Timslk's Avatar
Default SLK antenna
The peice that holds the antenna base into the hole in the fender is missing, dealers say it is part of the entire antenna assy, $65 - 143, any input from anyone?
Orb the Impaler
Sep 23, 2008 11:33 AM
nmtt92
Jun 1, 2006 11:45 PM
Napster
Jan 24, 2006 11:13 PM
97tripleblk
Dec 12, 2005 09:12 PM
mbdave
Nov 24, 2003 12:04 AM
