Loose antenna
My antenna is loose at the base, how do i access to tighten?
It's a 2000 SLK 230
Remove the antenna from the base, there is a screw to tighten it down.
Antenna
Originally Posted by livefreeordie
(Post 155560)
I never removed mine, i know there is a nut under the wip that comes loose over time. On the underside of the base there is either a flange that fits snug to the underside of the fender or there is a second nut/washer that came loose as well. You can get to it by removing the plastic panels on the inside of the trunk/boot.
(Post 155579)
Anytime. Did you get it fixed?
(Post 155634)
You may have already solved you rantenna problem, but here is a great site I saved when I had an antenna problem. Choose your car and it has numerous pictures that walk you through it.
www.AntennaMastsRus.com Good luck |
SLK antenna
The peice that holds the antenna base into the hole in the fender is missing, dealers say it is part of the entire antenna assy, $65 - 143, any input from anyone?
