Door hinge lub
Old Jan 15, 2006 | 02:01 PM
BikerDrew's Avatar
Default Door hinge lub
Does anyone The CORRECT lubricant type and procedures for lubricating door hinges? Thanks in advance.
Old Jan 16, 2006 | 03:04 AM
bazzle's Avatar
Default RE: Door hinge lub
Correct?
I use aerosol motorbike chain lube. Spray on wet, it wicks into the hinge and half sets to a greasy film.
Wipe off excess.
Bazzle
Old Jan 16, 2006 | 03:53 AM
BikerDrew's Avatar
Thanks BAZ. I have some and will try it. I was wondering if the motor company had some sort of fancy fluid. And a proceedure other than the "goop it on and let it absorb" method. Actually, chain lube sounds like a superior product. Do you use a foaming grease type like Bell Ray, used for o-ring (sealed) chains?
Old Jan 22, 2006 | 07:33 AM
bazzle's Avatar
Similar foaming type. Then wipe off excess after a bit.
Bazzle
Old Jan 22, 2006 | 02:38 PM
BikerDrew's Avatar
Thanks for the input!
guitartom
Aug 15, 2012 02:49 PM
bdaved
Nov 12, 2011 01:32 AM
landsteam
Nov 5, 2011 09:26 AM
brookings
Jul 9, 2009 11:29 PM
wagoner
May 2, 2005 11:37 PM
