CODE: P0170 & P1584
Old Oct 19, 2005 | 02:45 PM
  #11
Lugnut's Avatar
Default RE: CODE: P0170 & P1584
There's a fuel trim malfunction. That's all I know. Why didn't your mechanic fix it?
Old Oct 19, 2005 | 04:03 PM
  #12
snowpups's Avatar
He recommend that I go into a MB dealership but I know it can be quite costly (i'm running on tight budget these few months).
Do you think it'll be a good idea to go into the MB dealer for a diagnostic and to get a print out of the diagnosis and go to a non-MB dealership to fix?
Old Oct 19, 2005 | 04:04 PM
  #13
snowpups's Avatar
I wonder if this is affecting my mileage per gallon. I'm running at 21.5 mi/gallon.
Old Oct 19, 2005 | 04:39 PM
  #14
Lugnut's Avatar
There are a half-dozen things that could be causing the problem. You listed them when you defined the P0170 code. Someone needs to troubleshoot them one at a time until they figure out what it is.
The fuel mix is likely a little lean. I only say that because the code indicates there is an air leak that is too large for the ECU to compensate for by adding fuel... as I understand it. A lean mix can be quite hard physically on the engine.
I'd take it to an independent M-B mechanic. A little cheaper but just as good, maybe better.
Old Oct 19, 2005 | 05:58 PM
  #15
snowpups's Avatar
Does anyone know a good independent M-B mechanic in the Los Angeles area?
Old Oct 21, 2005 | 02:15 AM
  #16
BikerDrew's Avatar
Thanks. I found them as you suggested: http://www.obdii.com/codes.html
Old Oct 25, 2005 | 11:11 PM
  #17
AMPM's Avatar
Air leak in the gas cap. replace it.
Old Oct 25, 2005 | 11:40 PM
  #18
Kajtek1's Avatar
ORIGINAL: snowpups
MMBZ in Glendora. 626 335 2013
chanto
Oct 4, 2006 08:00 PM
joaohf
Aug 6, 2006 04:38 PM
contractsguy
Jul 7, 2006 03:51 AM
snowpups
Dec 15, 2005 04:11 AM
ahasanat
Jan 9, 2004 02:23 AM
