tire noise
Old May 23, 2010 | 11:19 AM
STEENER's Avatar
Unhappy tire noise
I have a low milage 2004 sl 500 with the original michline pilot sport tires that are so noisy i don't enjoy driving the car. They have 10,000 miles on them but i think i need to replace them. Anyone had a similiar problem or have a recomendation on repacements?
Old May 23, 2010 | 06:06 PM
grigorean's Avatar
As i know from tires dealers , those must be replaced after 4 years because the material is degraded.But it may not be your problem.Try to describe this noise.Maybe you should to echilibrate your wheels?
Old May 24, 2010 | 07:40 AM
ab4jy's Avatar
Default tires
i just replaced the tires on my 03 sl with the michelin pilots
and they are somewhat noisy, i think it is the nature of the compound
for that type rated tire... but certainly the noise is not a bad as that
you are describing..
glen
Old May 26, 2010 | 04:31 PM
96SL500's Avatar
From: Manatee County, Florida- Sarasota mailing address
I recently replaced my tires on a 96 SL 500 with Michelin Pilot Exalto A/S H rated. They aren't as quiet as the worn Michelin MXV4's that I took off but they were recommended as being a quiet tire. I have the 2010 CU Buyers Guide suggesting no tires are rated better for noise. About 7 tires are rated VG, the rest are good or fair. I have no complaints although one tire had to be replaced because the tread squirmed and it wouldn't balance.
Old May 26, 2010 | 05:14 PM
gilgorm's Avatar
You didn't mentioned whether they have been noisy since new or whether this is a new problem. However, tires beyond 5 years old start to harden and small cracks may start to appear inthe tread. They will get worse as time goes on especially if they are exposed to a lot of sunlight (i.e. not garaged, for example), electrical motors etc. But often, just time destroys the flexibility of the rubber and they may sound a lot noisier as a result. Your low mileage should have no bearing on the problem.
The Pilots are usually favorably rated.
Cognizant
Jan 11, 2019 12:26 PM
bsamuel
Feb 23, 2011 08:53 PM
safeway
Aug 10, 2008 10:21 AM
mapi
Oct 22, 2007 03:58 PM
sdunne
May 10, 2004 02:18 AM
