Sun Visor Removal
Old Jul 27, 2006 | 01:03 PM
aharley1's Avatar
Default Sun Visor Removal
I have a 1988 560SL. Anyone know how to remove the sun visor? I have a shop manual but it doesn't tell.
Old Jul 27, 2006 | 11:52 PM
Laterthatsameday's Avatar
Default RE: Sun Visor Removal
You have to pull the mirror off and remove the screws for the plate. And then I think there is another phillips headed screw through a small hole along the edge. It's been awhile since I've taken the trim off a SL, seems like it's also stuck along the front edge with some black sticky tar like adhesive. After you get the trim off you can get to the visor scew.
Old Jul 28, 2006 | 09:28 AM
aharley1's Avatar
I figured it out... Remove screw from outside edge of visor. Then, locate the hidden screw in th ebottom of the trim piece & remove it. Next remove the screw from the other end of the piece the visor tab goes into. Gently pull the trim back at the edge near the door post. There's another visor screw under the trim piece. There's FOUR wires going to the visor light...figure that one out! There's just 1 light.
Old Jul 28, 2006 | 10:37 PM
I think two of the wires feed the light on the other side.
Barry Hanna
Mar 3, 2019 01:51 PM
wpimetnel
Oct 19, 2007 08:48 PM
C28O
May 20, 2006 02:06 AM
pmjbenz
Jun 23, 2005 11:55 PM
pear
Jan 11, 2005 12:10 AM
