1983 Euro 280sl Front flywheel grinds on sub-frame when stopped on hill?? Why??
Old Jul 28, 2006 | 09:11 PM
jdogsarman's Avatar
Default 1983 Euro 280sl Front flywheel grinds on sub-frame when stopped on hill?? Why??
Car:
Euro 107 with the 110 (I think) in-line 6 engine and a 5 speed manual transmission.
Problem:
When stopping on hills, med-high grade, the front main (timing) flywheel on the engine rubs aginst the center of the front cross member of the sub-frame.
This also happens when braking while moving in reverse at all but very low speeds.
Tried:
I have recently replaced the sub-frame mounts and the engine mounts. The old engine mounts were completely separated. The new engine mounts were not the exact replacement but were practically identical on side-by-side comparision and stood a bit taller than the old ones that were removed.
Shortly after I discovered (by actually reading the paperwork that came with the car) that the sub frame mounts had been replaced onaly a few years ago, though my mechanic said they were compressed and the wear indicators were all the way down.
I had the transmission mount inspected, and actually had a new one to install which turned out to be a slightly different part--the one in place has some kind of adjustment and the new one I had was solid/non-adjustable.
These changes have only made a small difference in the symptom.
So.... it seems that when there is backward force on the wheels that either the sub frame is twisting up toward the front or the engine is tipping down in the front...
Any Ideas from the crew??????
Thanks in advance,
Jason
Old Jul 29, 2006 | 12:50 AM
TheV12pwr's Avatar
Default RE: 1983 Euro 280sl Front flywheel grinds on sub-frame when stopped on hill?? Why??
It seems that you got yourself a lemon....
belized
Jul 21, 2011 12:05 PM
280sl_oz
Mar 11, 2011 10:12 PM
therichzone
Jul 14, 2010 04:04 PM
JessicaArana
Oct 4, 2008 09:51 PM
teo977
Apr 14, 2004 10:00 PM
