SL500 MY 2000 - Soft Top will not retract
I have a 2000 My SL500 that has been in storage for about a year. I have started it every 3 months and have used Gas Stabilizer.
I Am getting it out of storage now that we have better weather. When I tried to drop the top. The rear window retracted but the front did not retract at all. There also is no sound from the front of the soft top.
Any ideas what can be wrong? I would like to fix this myself but am also taking it to the dealer in a few days and will have them look at it if I can't fix it soon.
Please help.
Please help.
might try locking down the top manually and trying again. does your manual show sychronization procedure for the top? there are micro-switches at each point in the sequence of opening and closing, they tell the controller what to do next. there is a micro-switch on the bow cylinder. does the storage compartment open? some switches/sensors can be tested easily in place, others not so easy. all can be tested at the controller harness.
Mercedes-Benz SL-Class R129 (1990-2002) Technical Articles - Pelican Parts
MI-Foodie I have the same exact year and the exact problem you had. Can't retract the soft top. What did you do?????? thank you len in michigan
Well fellow Michigander I am not sure that I can be of too much help. I took out the fuses for the soft top operation and inspected them. Nothing was amiss so I put them back. The next day the top retracted.
Good luck.
Good luck.
Max Macson
Apr 20, 2011 09:18 AM
kohiba
Aug 24, 2008 07:39 PM
