SL Top Leaking Hydraulic Oil
Old Jan 19, 2011 | 08:32 PM
  #11
MaritimeBill's Avatar
Originally Posted by SunGuy62
The 'source' is the hydraulic cylinder's seal that activates the left side latch has split and is leaking fluid. The step x step instructions to remove both of the front cylinders are here...
Update 10-18-2010: The instructions + Pics have been removed for reasons I don't quite undersand, so if you need them, pm me. Sorry for any inconvenience.
These cylinders should always be rebuilt in pairs, as repairing just 1 will put added hydraulic pressure on the remaing one, then that seal will probably go. Once you have them both out of the car, you can send them to the rebuilder I posted above. His charges for rebuilding are about 1/3 of what a new cylinder would cost...and they work!
One last thing, if you've lost enough fluid so that the pump reservoir has to be replenished, you can buy the expensive MB branded fluid, or Febi-Bilstien Fluid, p/n#02615; same stuff for less from any of the online MB parts sellers.
Good Luck
Bob
After fearing the inevitable/eventual hydraulic leak for the convertible top it happened to my 99 SL500. Try Tophydraulicsinc.com . They have a printout for good instructions. Easy to remove cylinders, send them out and return in a few days. Very reasonable cost, 30 minutes to remove/less to replace. Piece of cake. :-)
randallrandall
Jan 4, 2012 04:30 PM
SLK230inFL
Apr 4, 2008 02:26 PM
Lugnut
Jan 14, 2007 12:31 AM
01slk320
Oct 9, 2006 05:05 PM
ferret
Jun 14, 2004 01:09 PM
