320SL Hydraulic top problems
Old Dec 15, 2003 | 12:16 PM
ferret's Avatar
Default 320SL Hydraulic top problems
<FONT face="Arial, Helvetica, sans-serif" color=black size=3>Any suggestions as to why hydraulic fluid is leaking from the windshield frame around the visors on both sides ('94 SL320)? Hardtop is on, but there is a constant drip on both sides. Anything I could check for and maybe do something to at least stop the drip? Also...how do you change an instrument bulb?</FONT>
Old Dec 18, 2003 | 08:15 PM
joes300sl's Avatar
Your cylinders are leaking that lock down top in front. They cost 150.00 or so a piece to fix. You can check by taking off cover 2 or 4 screws hold it on.
Old Apr 28, 2004 | 06:17 PM
emb145fo's Avatar
Default RE: 320SL Hydraulic top problems
Do they need to be taken to the dealer or is it an easy fix?
Old May 17, 2004 | 08:06 PM
MB-500SL's Avatar
Hi there
Actually I have some hydraulic problems too !!
The unit that you need to replace can be installed quite easily.
So you don't need to go to an official dealer.
If you want I can ask for you how much they charge 4 it in Holland cause
I get 20-30 % discount at a parallel import for mercedes parts direct from Mercedes Benz !
The bulbs you can replace quite easily too:
order 2 special tools at your mercedes dealer: it is a hook
a special tool, like a screwdriver with a hook (90 degrees)
Then you place it gently on top of the instrument panel
left and right and then you can pull gently.
Please note don't damage your dashboard !!!
Also I have found a solution to put BLUE light in your dashboard !!!
It looks pretty cool and makes the car 5 to 10 years younger
Have a nice day
regards from Holland
Hans
Old Jun 14, 2004 | 01:09 PM
zorba's Avatar
I have the same problem in my '94 SL320, glad to know it is relatively cheap to fix, especially since an estimate I received was for MUCH more than that.
Thanks!
absaroke
Sep 5, 2009 09:57 AM
zouzou
Jul 10, 2009 12:44 AM
jimbo409
Jul 3, 2009 04:49 PM
deangeorge
Nov 7, 2008 05:25 AM
scottyc
Jan 31, 2006 09:42 PM
