r129 sl300 roof cyl kits
Old Dec 2, 2007 | 07:40 AM
muso58's Avatar
Default r129 sl300 roof cyl kits
hi im looking for a source for roof hydraulic cylinder repair kits .the nearest i got was from a guy who repairs them in the USA .Rather on the expensive side . i will shareany info i get as thats the way it should be. i have already stripped down one, of the top of screen cylinders and effected a temp repair with an adapted brake cylinder seal .but would like a more permanant answer.If anyonehas any info ie cyl/system manufacturer. part nos etc .would be v interested . i am going to be looking round car shortly to get manufacturers names etc,and will post as and when .this is going to be a larger as larger issue as these old girls get older, will even consider having kits manufactured as i have a contact in the hydraulic industry.
thanks for looking
Old Dec 3, 2007 | 12:58 AM
brookings's Avatar
Default RE: r129 sl300 roof cyl kits
be careful if you ever have a problem with a leakin therear. I had a problem on the drivers side. lifted the top cover and looked down and sure enough the lower larger cylinder was leaking or so I thought. well it was wet with hydraulic fluid right where the rod comes out. but what was happening the smaller cylinder that raises and lowers the back part of top was leaking right down on top of the main cylinder. you can hardly see it buried in the hardware. follow the wire or look close. the larger main cylinder ran $500 of which I didn't need. the upper smaller one with the built in micro-switch is $600 plus. and those are not suggested retail, but a dealer can give those prices if they are in the mood to be nice. the one on the other side is a lot less without the micro-switch. the main cylinder isfairly easy to replace. the smaller upper is harder. the front ones are the easiest of all. try mercedescylinders@sbc.net for getting it rebuilt if you don't want to give an arm and leg for it. maybethey arethe ones you already knew about. compared to newthey arevery reasonable
Old Dec 3, 2007 | 07:59 AM
SunGuy62's Avatar
brookings,
The link you provided takes you to the Southern Baptist Conference website. I think you meant to post Dennis Ficken's email address...
mercedescylinders@sbcglobal.net
Bob
Old Dec 4, 2007 | 03:08 PM
brookings's Avatar
oops!
MI129
May 8, 2013 01:54 PM
MI129
Feb 20, 2013 02:49 AM
vinh111
Dec 17, 2008 05:27 PM
Harlow
Nov 11, 2007 11:11 PM
edwardwright
Jan 5, 2005 12:23 PM
