Oil slick under car
Old Aug 18, 2017 | 05:59 PM
hgreg50's Avatar
Default Oil slick under car
Drive car came out an a 4ft oil slick under the car. Not sure if oil or tranny. Engine starts as normal with no emergency lights coming on. Afraid to drive car. HELP
Old Aug 18, 2017 | 06:27 PM
PelicanParts.com's Avatar
What year and platform is this in regards to?
Old Aug 18, 2017 | 07:28 PM
hgreg50's Avatar
Default Oil slick
Md 2004 sl500
Old Aug 21, 2017 | 02:38 PM
Since your car is OBDII, I would suggest pulling the codes from the DTC. This will give you a definitive answer as to where to start looking.
Old Aug 26, 2017 | 09:43 PM
NiceMerc's Avatar
Could be ABC fluid barf? My 2004 did this recently while sitting in the garage.
I lifted the hood and could see it came from the ABC fluid reservoir. No warnings or codes. I had it checked by my indie. He couldn't find anything, but topped it up and put a new seal on the reservoir just in case.
I noticed that the ride had deteriorated and read about ABC fluid barf happening when an accumulator or dampener blows. I also read that when they blow they are likely to put debris into the remaining ABC fluid and that is likely to start working its way around the valves and seals causing more problems in the future. I had planned to get them replaced in the fall, so I brought that forward and had them all (4) replaced a couple of weeks ago. The parts aren't too expensive and labor on 3 is OK, but the return dampener is buried so it took them a while to get out and replace. Ride is much better now.
Hope this helps.
Gary
Old Aug 27, 2017 | 07:22 AM
hgreg50's Avatar
Thanks for the tips. As it turns out it was the abc pump and fitting.
Old Sep 27, 2017 | 01:16 AM
brookings's Avatar
what was the condition or color of old fluid or mileage on old fluid?
GDAD
Sep 24, 2008 02:32 PM
GDAD
Sep 23, 2008 10:49 AM
amore76
Oct 25, 2006 03:39 AM
dcjohnston
Jul 23, 2006 04:07 PM
Lugnut
Nov 15, 2005 06:17 PM
