HEADLIGHT WASHER
Old Aug 9, 2007 | 09:29 PM
mdanielson55's Avatar
Default HEADLIGHT WASHER
JUST BOUGHT A 1998SL 500 AND BROUGHT IT HOME AND SURE NUFF AFTER MY WIFE CLEANED THE INSIDE{TOOTH PIC AND TOOTH BRUSH CLEANING] THE HEADLIGHT WASHER KEEPS SQUIRTING WATER TILL EMPTY. HEY DIDNT ACT UP ALL THE WAY HOME BUT NOW DONT KNOW HOW TO STOP IT. ANY SUGGESTIONS OR TIPS THANKS TONS MIKE
Old Aug 9, 2007 | 09:43 PM
ItWontBeMyLastBenz's Avatar
Default RE: HEADLIGHT WASHER
I've got the same problem......No help for you, just know there's others with the same problem.
Mark
Old Aug 10, 2007 | 01:44 AM
TheV12pwr's Avatar
There is a recall for that.
http://auto-recalls.justia.com/conte...LASS-1996.html
Old Aug 10, 2007 | 11:33 PM
paddlemarv's Avatar
Make sure the wipers are laying above the glass mound on the headlight. If not, swing it open and loosen the nut. When adjusted, tighten the nut. Work the wipers with the headlights on and then turn them off. See where the wipers end. They should be above the protruding tit. If not, loosen and realign.
Old Aug 14, 2007 | 05:17 PM
BCinPhx's Avatar
Ditto Paddlemarv above....worked on mine. I left the nust to the wiper arm loose and ran the washer thru the cycle with the lights on and then turned them off and aligned the wiper blade above the tit and tightend nut.
gaby88
Mar 5, 2010 03:29 PM
pejaife
Jan 9, 2010 01:16 PM
paboone
Dec 5, 2008 10:33 PM
adam52396
May 21, 2008 03:36 PM
Austin300d
Jan 21, 2008 11:00 PM
