Headlight Washer Stuck On?
Old Jan 21, 2008 | 11:00 PM
Austin300d's Avatar
Default Headlight Washer Stuck On?
Quick (however may not be permanent) fix:
Car: '87 300D Turbo
Problem: Headlight washer pump stuck on, constantly spraying fluid on the headlights anytime the switch for the lights is in anything but the "OFF" position.
Solution: Manually re-align the headlight wipers to be sure they are not stuck below the headlight or being prevented from wiping back and forth.
I tried this just now, and the fluid pump motor finally turned off when the lights were activated.
Hope that helps you out.
petermerc711
Dec 24, 2010 05:47 PM
pejaife
Jan 9, 2010 01:16 PM
paboone
Dec 5, 2008 10:33 PM
adam52396
May 21, 2008 03:36 PM
mdanielson55
Aug 14, 2007 05:17 PM
