electric seat problem,1993 320 sl.
Old Jul 20, 2005 | 03:01 PM
asa001's Avatar
Default electric seat problem,1993 320 sl.
i have a mercedes sl320,1993.the electric seats no longer work in any direction.the control panel was very temprimental for some time before this,but would work from time to time.any ideas? do i need new control panels? many thanks, asa.
Old Jul 21, 2005 | 04:45 AM
SL600_Cruzin's Avatar
Default RE: electric seat problem,1993 320 sl.
Check the Relay located in the Fuse Box - Should be K24 Relay - or see the bottom of the fuse box cover.
hopefully this helps
Old Jul 23, 2005 | 08:17 AM
bobterry99's Avatar
You can check the K24 relay mentioned in the prior post by checking Fuse #4 for battery voltage. Also check fuses E and F. If all of these are fine, then you need to check inputs to the controllers and outputs from them. Email me for a schematic.
Irishclk
Feb 17, 2022 10:56 AM
volcane
Nov 25, 2007 01:26 AM
rsmartin
Sep 2, 2006 01:26 PM
lovekystrike
Nov 17, 2005 03:38 AM
honeyuzi
Jul 24, 2005 06:00 PM
