30 Gearbox
Old Aug 31, 2013 | 01:42 AM
JTPerth's Avatar
Default 30 Gearbox
Hi Guys, I have owned my SL500 for over 2 years now, has 51k on the clock....I recently went for s drive, and it wouldn't change up/down gears....stopped the car, shut off the engine, restarted it & presto, sprung back to life & roared away.........anyone with any ideas or similar problems?.....Thanks Guys & Gals
Old Aug 31, 2013 | 04:12 PM
SunGuy62's Avatar
What model year is your car?
Where are you located?
Old Sep 1, 2013 | 11:39 AM
JTPerth's Avatar
Default year of car
its a 2003 and i stay scotland....any help would be preciated
Old Sep 2, 2013 | 03:51 PM
SunGuy62's Avatar
The way I read what you described sounds to me for some reason your transmission was put into 'limp home' mode. You can do an advanced search in this forum on that term and get a better explanation.
When you turned the key off and then restarted, whatever the error was reset. If it doesn't happen again, I wouldn't worry. However if you're curious or it does happen again, the error code that put the trans into limp home is stored. It can be accessed via Star Diagnostics from the dealer or an independent garage.
Adam
May 9, 2005 06:26 PM
toien
Aug 9, 2004 08:39 PM
babyman
Jun 9, 2004 08:27 AM
christina1939
Dec 11, 2003 06:55 AM
jocor
Nov 19, 2003 07:21 AM
